Re: Clutch Dogs for 1963 28 hp
I would make sure your shift linkage isn't out of adjustment before you tear it down. These are adjustable and often times need to be re-adjusted. You'll find two clamping bolts on the shift handle. Often times, the shift rod loosens up at the bellcrank, which is under the powerhead and at the end of the shifter shaft.
Clutch dogs going out and gears being swapped is often times a wives tale. In your manual transmission cars, adjusting the clutch is a routin maintenance proceedure. Well, adjusting shift linkage on a big twin is too. Unless water intrusion has been an issue in these lower units, they seldom wear out. I've found BUNCHES of them that worked great after a minor adjustment. The only time you need to replace stuff is if you see obviouse damage to the parts. If you check the gap between the shift fork and the clutch dog, it should be okay to use, if it is under .010
