Re: 85 force o/b 85 dies off under throttle
ok john, took it out yesterday afternoon. ran about a gallon of mix and seafoam, pulled plugs before i ran it, sprayed seafoam in all 3 cylinders, let it sit for about on hour, started it up, smoked like a freight train, compression checked about the same. sprayed again, took it to the lake, ran about a gallon of mix and seafoam... started fine, idled better than last year, runs good to about 1/2 throttle, still not breaking plane at this point, but begins to sputter past 1/2 way... but stabbed the gas hard once, and it picked up full speed, broke plane and took off for about 20 seconds then died back off... squeezing the bulb has no effect and is good and firm.. do i need to take the carbs off and clean them? or do they need adjusting? or is this something else?
