DONPhantasmo
- Dec 30, 2008
- 22
I have a 1998 Wellcraft with a I/O 3.0 Volvo-Penta. last year, I left the plug in after going out fishing, and I came back, covered it and went to go out the following weekend, but the boat had a bunch of water in it. It was 1/3 of the way up the engine bay.
I went to take it to the marine stores around here, but NO ONE will work on a Volvo within a 50 mile radius of New Orleans.
I had to do the work myself. I trouble shot the issues. I knew I had to buy a new starter, so I did. I also read out the relay (good, no need to get a new one), and I also checked the circuit breakers, needed a new one, so I ordered it. Everything came in, and it was too cold to work on the boat.
Finally it got warm, and the rain stopped. So, I put the starter in, no prob. Wired it exactly as the book and the instructions said. I replaced the breaker, and everything was ready. Put some starting fluid in the Carb, and here we go...
The boat turned and turned, and nothing. Then, it started. As soon as I took my hand off the key (from start to run), the boat would die... It did that about 4 or 5 times. Every time I'd start it, it would actually run, until I return the key to the "run" position, and it would die.
I've read the wires, and they all seem good. I might not be reading everything correctly. I've even read this forum, and even read the troubleshooting manual, NOTHING.
Has this ever happened to anyone? Started fine, then when you returned the key to run, it would die?
If so, what did you do/
PLEASE HELP!!!
Thank you in advance!!
PLEASE HELP!!!
