Re: Help w/ 6hp evinrude. Difficult steering
As a long time salt water dealer mechanic, I know exactly what is wrong with it. Corrosion around the outside of the upper swivel bearing is squeezing it tight against the pivot shaft. There is only one way to fix it---take it apart and clean the crud out of the swivel bracket and re-lube everything and reassemble. If you are careful and don't break anything, no parts are normally required.
It is not nearly as hard as it appears. You will need:
1. Something heavy to clamp the motor to, such as a boat.
2. Something to lift several hundred pounds, such as an engine hoist or a couple of guys with gorilla arms.
Remove the clamshell housings from the lower motor mounts. Lock the tilt down. Lift the motor while steering it back and forth. The pivot shaft will come up and out of the swivel bracket.
Now, there is a pin holding the upper bushing from rotating. It resembles a rivet. You tap it out with a punch from the outside, toward the inside. Once that is out, notice the slit downone side of the liner/bearing. Carefully pry one side of the slit toward the inside. Once the edges overlap, the bushing can be pulled out easy. Also remove the co-pilot plate and rubber spacer.
OK, cleanup time. You will find a ton of corrosion in there where the liner was. Scrape it all out. Make sure all zerk fittings are open and will pass grease. Many motors do not have an upper zerk, or if it does, it may be a dummy one with no hole. That's fine, you are supposed to lube it from the bottom till the grease comes out the top.
Got it all cleaned up, grease everything well with waterproof marine grease and reassemble the same way you got it apart. And from now on, don't neglect it.
