Mas
- Oct 3, 2006
- 1,656
Well, today I tore into the gearcase to see if I had a bucket of rust. I drained the gear oil that I temporarily added, and it looked rather clean. The nine screws holding the lower half easily came out...so that was a good sign too. I rapped the skeg with a rubber mallet and opened it up to see an absolutely clean gearcase. No Rust!!!! And, very little wear!!!
I found out why the LU did not shift was because the shift lever was slightly bent which caused the cradle to slip out...thus caused by the missing shift lever pin in the LU when I purchased the motor. The shift lever was only slightly chewed...but no damage to the bevel gears or anything else. I easily reformed the shift lever and reinstalled with the cradle. The LU now shifts perfectly. The shift dog also showed little wear.
While cleaning the LU I carefully removed the pinion gear to inspect...only to have all the larger barrel bearings fall out. They will never be replaced in the exact orientation unfortunately. Luckily, the entire gearcase showed little wear. The only issue is the prop shaft seal housing needs to be replaced. There was a hole eaten through the metal and would cause a problem when the seal is replaced. Hopefully, I can find one easily.
Check out the pics:
Mas
Check out the pics:
Mas
