Re: Want to buy a cabin boat and need advise
I agree you can't judge a boat's care by it's brand. I've seen some really nice boats (new) that were trash in 10 years.
My Glastron CV 23 looks like new. It had one refit on the upper deck upholstery since 1977, the cabin is original and like new. The boat is kept covered up when not in use, there's nothing like the sun beating down on a boat to ruin it.
My son and I went to Illinois last spring to pick up a boat identical to mine for him. He's a spoiled jet boater for life!
That's about as far as I would go for a boat, it was a long haul. We went out, spent the night and brought the boat back the next day. Fortunately it was exactly as described. He sent many detailed pictures so I pretty well knew he wasn't trying to hide anything.
Since I'm not looking for a newer boat I'll probably stick to the sea ray or Wellcraft type brands then. If the bayliners were made cheaper their life span is probably about up. Meaning in need of more repairs, there again depending on the care the owner gave it.
I do all my own mechanical work from building the engines to rebuilding the jets. If it doesn't need machined we do it in house. If I need special tools I don't mind spending the money on them. That's because as with my 1977 Glastron, when I buy it I'll make sure it's what I want and keep it!
I can allways pass them on to my other son. I think he's waiting for that!
It's gonna be a long time yet I hope
Do you know of any pit falls I should be watching for? If I go look at one what areas should I be keying on as far as the drive and steering? Where does the water usually hide if the windows leak etc? What's the best way to check the gimbal bearing etc?
How do the trim tabs and power trim work? Are they powered off a pump on the engine or 12V remote? If I look at one now it will be winterized and probably won't be able to start the engine will I?
Do they all have power steering or not on 1990 and earlier?
I don't plan on going over $15000. for this boat. I will only use it when we plan on spending a couple days at the lake. Single days will always be the jet.
Thank you for my education!
