I bought a 1968 9.5 HP Johnson outboard a few years back and it's always done great until this past summer. It won't idle for long when I can get it started, on the water it will run with the throttle wide open but only for a few hundred yards before it starts to jerk and cut out. It seems to do better with the hood off and will run if I spray starter fluid into the carburetor every 20 seconds or so . The carburetor seemed to have fuel leaking from it but not from a central location. It looks wet from top to bottom. I bought a Seloc repair manual it helps for repairs and maintenance, but doesn't have a great trouble shooting section. I've cleaned the carburetor, replaced the plugs, wires, fuel pump, water pump, fuel tank, fuel line, and fittings. The plugs fire and the carburetor gets fuel. I have not checked the compression. I'm new to the world of outboards so I hope I gave you enough to go on. Thank you.
