Hello Folks,
You guys really helped me out last year and it was appreciated very much. I have another problem I hope you can help me with.
Volvo Penta 3.0 with new riser and elbow runs well but am now seeing a rapidly fluctuating temp gauge. It will sit at 160 and then go to 180 and then back to 160. When it drops to 160 you can actually see it move, iow it goes from 180 to 160 in less than 3 seconds. I know the thermostat opens at 160 but at what temp is it fully opened? Is this rapid fluctuation normal or should I be staying at 160. I don't notice a pattern when accelerating. It happens regardless of idle or speed. Do thermostats adjust that quickly. Should I replace the thermostat? It does sit at the appropriate thermostat temp of 160 frequently which makes me think it is working correctly.
My manifold and elbow is barley warm, the only hot hose is the thermostat to the water pump hose. I can hold my hand on the valve cover for about 3 seconds as that is the only hot area. It has a new thermostat and sender and impeller.
Thanks guys
Thanks guys
