1996 Johnson 6. just bought 3 months ago with 23 foot ericson. i have no idea of past maintenance. for the past 3 months as soon as i started the engine, water flowed from the pee hole. Is this normal?
Today i am getting no flow - even after 5 minutes.
However there is water in the exhaust.
I checked the intake and the pee hole and there are no obstructions.
I pulled the thermostat (which looks broken) and re-seated the thermostat cover and started the engine for 30 seconds.
While there was still no water flowing from the peehole, there was both leakage from thermostat cover and there was water in the exhaust.
It seems that the engine is getting water
When i pulled the thermostat, should i have gotten water out of the peehole?
I will replace the thermostat.
Should i replace the impeller?
Is it a big job? any advice?
thanks in advance
Joe
thanks in advance
Joe
