Re: Converting Rollers to bunks
A couple of comments here...
1. Why is it when someone is considering a roller to bunk conversion, they are always looking to put down 2x4 or 2x6 as bunks... Why not do the 4x8, 4x10, etc. beams like you find on new aluminum trailer setups...
I ask this because I have a Magic Tilt trailer that has the beams. It is very easy to load, it self centers, only has a roller on the rear crossmember and the boat never touches it... In my opinion, this is the best trailer setup for most v-hull boats...
2. I also have to disagree with JimS. THe boat does not have to have keel support... You ask for references to back up the comment, Look in most boat yards. and I do not mean small watercraft, look at the 30+ footers that the marinas pull out the the water and store on stands for the winter... I bet you will find that 90% have no keel support, but have 4 or more stands under the hull to spread the weight/pressure of the boat...
In my area (not sure if it is due to popularity) but most of the trailered boats in my area are on trailers as I described above, Beam Bunk only, no rollers... easy to load, low maint trailers, light and easy to tow...
I am not saying that one setup is right/wrong or better/worse than another... Just wondering why the beam bunks are not considered in a conversion. Practice with any trailer makes loading easier, but the setup can make a huge difference...
