Hi, I have a 15 hp Johnson 1983 long shaft that was in need of a new water pump. I change the pump and noticed that the water pickup tubes rubber gromet was big on the upper end. The water tube is 3/8 inch and the mouth of the gromet is at least 1/2 inch and doesn'r narrow down untill it get into the water pump. to make a long story short, it leaks water out of the shift rod gap in the leg and the upper vent in the lower leg. I have a very weak stream at the tell tale. Is it normal for the pickup tube grommet to be this bell shaped? Is this were the water is leaking? Any help would be appreciated. Thanks.......Robert
