Fire comes out of carb
victorc1
Okay I rebuilt my 1995 Mercruiser 3.0 LX, changed piston rings, crankshaft and piston bearings, rebuilt the head, new gaskets and hoses. I did not touch the camshaft bearings because the owner before me did it already. Okay, so when I try to start the motor flames come out of the carb and the motor does not start. Can someone help me Please?
Also I used 5 cans of black motor paint...
JustJason
Re: Fire comes out of carb
start with a compression test and come back with the results.
Bt Doctur
Assuming you lined up the cam to the crank correctly, then suspect the timing is off. Did you install it with #1 at TDC compression stroke?, firing order 1,3,4,2.
victorc1
Before I started it I checked the compression on the 4 cylinders, 120. I aligned the crankshaft with the camshaft gears and set the damper to 0 TDC, the rotor points to the the number 1 spark plug wire.
Don S
You are 180 out when the cam and crank marks are aligned.
victorc1
What does that mean? I did exactly as the manual describes.
Don S
It means you are not on #1 TDC on the compression stroke when you installed your distributor.
It takes 2 complete revolutions of the crankshaft to accomplish all 4 strokes of a 4 stroke engine.
Look at page 4B-10 of manual #13. It explains how to find #1 TDC on the compression stroke.
victorc1
I aligned the timing marks on both gears exactly as described in the manual page 3a-39.
Don S
I know you said that, but that is not #1 TDC on the compression stroke. That is just the cam and crankshaft timing.
victorc1
Okay I'm going to the boat now with page 4B-10, I'll try it and get back to you. Thanks.
a70eliminator
Your valve timing is correctly set as you describe lining up the crank and cam keys.
Distributor position effects ignition timing and although you rotor is pointed to #1 the piston may be on it's exhaust stroke and not compression stroke.
Don S
You don't line up the keys, you line up the marks on the cam gear and the crankshaft gear.
attachment.php
Ridemywideglide
Easiest way to check for being 180 out.. Turn the distributor 180 off and try to start it.
a70eliminator
attachment.php
Pip marks, not keyways ok, my point was valve timing and ignition timing are two totally different things.
Ayuh,... I agree with the current diagnosis,... Timing out by 180?...
About the only other thing I can think of that'll do that is,.. The Valves are way Too Tight...
FreeBeeTony
i don't even think it takes 180* to get a flame outa the carb......it happened to me during the initial start-up after I replaced my heads.......thought the timing was close enough for the 1st start up but not quite. I had about a 4' flame come out of the carb......just about took my son's eyebrows off........:) just needed a little adjustment for the initial start up after that.
JustJason
or you could just do a compression test, and you'd know that your having a power stroke wanting to happen while the intake valve is still open.
Alpheus
K.I.S.S. method. put your finger over the # one sparkplug hole, turn the engine over by hand until you feel the pressure under your finger building up. Then you know its on the compression stroke...
victorc1
Thanks Don, I did exactly as described on the page and it started perfectly. Only the motor sucks air in through the carb gasket that goes between the carb and manifold. I am using the old original gasket because it is like a spacer type gasket and the gasket that came with the kit is not. I am afraid that if I use the new gasket because it is thinner, the heat from the manifold will heat up the carb. Could I use the new gasket or will I need to find the spacer type?
Don S
Yes, using old gaskets will cause leaks. Get a new one. Merc still sells them.
The Merc part number is 8079821.
Just use the new thin gasket you have to get things going until you get the correct one.
