Stachi
- Jul 14, 2009
- 1,671
Re: What do I need for my maiden voyage?
is the sewing kit for vinyl or skin?????
Looks like you have a good start. Do some searching here as there are lots of lists like this. I have a couple of quickie suggestions to add.
Need a throwable type of life preserver too, required.
I always recommend adding the thrust washer. If it comes off with the damaged prop (grease will make it stick to the most forward area of the prop) and if it drops in the water, you are screwed . . .
Also, some sort of tool kit for minor quickie repairs. Wire stripper, connectors, loose wire. Screwdrivers, wrenches, pliers, vice grips, electrical tape, zip ties, hose clamps etc.
3 - 4 Specific dock lines, 1 bow, 1 stern and 1 spring minimum. And a very long length to use for all kinds of things that will come up. I like 150 ft.
My favorite item on the boat, and I use it a lot, is a sewing kit . . .
