I bought the motor about a month ago and when the seller went to test run it, it was cold and it took a few pulls (5-10) and then it fired up and ran fine. I pulled the carb, took it apart and the fuel pump parts and carb seals/float looked like they'd been replaced not too long ago. I sprayed it with cleaner then blasted it with an air compressor.
I got the LU back today from getting re-sealed and put everything back together and tryed to fire it up in a bucket:
All my fuel lines are brand new, new tank open vent, good gas, I played with the choke, idle speed screw, and carb lean/rich adjustment for about an hour. Fuel filter is clean. New plugs. The best I could get it to do is fire up for for 10 or 15 seconds it would run fine then make a puff noise from the exhaust and stall out.
Can anyone diagnose my issue or point me in the right direction? Should I buy a cheap compression checker and check the comp.? Should I try and dunk the carb in fluid over-night?
Thanks for your responses
