Re: Merc 5.7 260 alternator problem?
An old, half dead battery is a major contributor to early alternator failure.
Like JJ pointed out, keep battery cable connections clean, bright, and tight, on BOTH ends.
Check water level, top up (only to the lower end of the fill neck) with DISTILLED water.
If the boat is un-used for an off season, either remove the battery for storage, recharging at least every other month, or install a marine battery maintenance charging system. (AC or solar)
Lastly, remove the battery, take it to NAPA for an annual load test. Replace when performance fails below acceptable level.
Batteries CAN last 4,5 years or more, IF cared for.
