Re: railing loose
as rbh stated; do your self a favor and re-bed them.
if there like the ones on our "88" weekender, this is how i did ours.
you need a philip head screw driver and 7/16, or 3/8 socket.
on ours i loosened enough to squeeze 5200 sealant all around the stanchion base. then tightened. the front stanchions nuts were able to reach from in side the anchor locker.
the next ones back are under the head liner. to get a socket on them, feel the head liner till you find them. then take a sharp razor knife and make a small slit just large enough to work the socket thru and on to the nut. the rest you have to look outside and get an idea where they are inside. inside the cabinets and ect on both sides
