Re: embarrasing carb/idle adjust question
I had a 3 cyl 70 but that's been a while ago and I forgot a lot. Trying to remember.
The (each) carb has/should have, a carb low speed adjust which is a brass (usually knerled) screw with a very obvious Stainless Steel spring mounted on it that sticks out some 3/8" from the carbs alum housings. It may be in the front, or on the side; I think OMC has it in the front and I know Merc has it on the Port side. The high speed adjustment is fixed and not accessible.
When he says 3 turns out I think this is what he was referring to. To check, once you find the screw, observe where it currently is (using the slot position as a reference) and very slowly and delicately screw it cw UNTIL YOU FEEL RESISTANCE.....do not tighten as you can easily cut a groove in the needle and totally screw it up as an adjustable element counting turns or portions of turns as you turn. If you turn 3 complete revolutions you have your critter he mentioned. It usually isn't out that far, but I would look at linkage (below paragraphs) before I would mess with this.....so, for the time being at least, return it to the position where you found it.
Other things can affect idle, in particular the linkage. Easiest way to check that is to look at the engine while moving the remote throttle lever back and forth, like from idle to half speed position. The remote cable (end that's inside the engine compartment) has a movable end on it that is connected to your throttle lever that you are moving on the front end and on the engine end, to linkage which ultimately winds up controlling the spark position (under the flywheel) and the carb's butterflies positions.
As you move it back and forth, notice the linkage movement and look for a set screw or two (I think they used white Nylon with a similar SS spring for this on these engines) that contacts the linkage, in particular contact that occurs when you bring the remote back to the idle position....I THINK these are on the starboard side on those engines.
Tweaking that screw will control your idle speed, obviously CCW to reduce rpm's.
HTH
Mark
