I'm looking for some kind of Oil Pan Drain system that has a fitting that fits in place of the regular drain plug. This unit will screw into the pan, and have a hose that leads out thru the transom drain hole. There will be a valve on the hose to empty the oil. Otherwise I will look into getting a pump of some type to remove the oil.
