jaybirddog11
- Nov 30, 2009
- 133
Motor- 1007H9A (1979 100 hp chrysler)
Hello, I am having trouble with consistent performance. Last weekend it seemed to run fine but when I got to the honey hole it would not start and needed to get the "tow of shame". I initially thought it may be my preamp or CD unit but thought I should start troubleshooting all wiring since I have been having trouble with consistency. I started with the magnapower circuit test as outlined in the CLYMER manual and could not get past the first step. That is to "turn the ignition switch on and connect a 12V test lamp between the terminal block blue wire terminal and a good engine ground. If the test lamp does not light, the problem is between the terminal block and the ignition switch. Mine does not light up. I have my boat wired as instructed in the book I think?? My switch is fairly new.
Yellow - S
White - M
Green - C
Red - B
Blue - I
BLANK - M
I have read other posts and saw that Blue should go to the other M terminal. I currently have it wired this way and it seems to get me past steps 1,2,3,4 and 5. Step 6 says "to move the test probe to the ignition switch B terminal. If the lamp lights, replace the switch." Well, my lamp lights up but I am confused why it should not light since that is the battery terminal. Do I need to replace my switch? Also I am afraid to try and start it the way it is currently wired. I did notice that the 'I' terminal now functions as an auxilary. Any help would be greatly appreciated.
Yellow - S
White - M
Green - C
Red - B
Blue - I
BLANK - M
