Re: One flat safety concerns with dual axles?
Lots of good MIS-INFORMATION in this thread. Readers should be aware that in many cases the information they are getting is worth exactly what they paid for it ......
Lightest tandem trailer for a 22' boat that I've found is rated at 5200. Jeez. The orginal poster would have no problem trailering a short distance with one flat tire.
You haven't looked very hard for tandem trailers for 22' boats. Almost every manufacturer starts them around 4000 pounds. And it's nice of you to make that determination for the original poster without knowing anything about the trailer, tire sizes, etc. A 600-700 pound dual axle trailer would be a VERY small trailer. For example, the lightest Easy-Loader dual axle trailer they make weighs about 900 pounds.
And I would not be running a tandem axle trailer without tires rated to carry the load on three.
If four is required to carry the load but not three, I am in worry mode.
Obviously typed by someone who doesn't have a dual-axle trailer, or sell anything for a living. No reason to go to the expense of a dual axle if a single tire on one side is capable of carrying the load. Only way you would be able to carry the load on three tires would be if the single tire was rated to carry MORE THAN DOUBLE it's normal load when all tires are working. In that case most buyers would go with the cheaper option of a single axle.
It's not real hard to figure out, pick any trailer manufacturer website and look at their trailer ratings.
The specs below are from the Venture trailer website (
http://www.venturetrailers.com/bunk.html). Pay attention to the load capacities of the trailers and the tire sizes.
The tire specs below are from Trailer Parts Superstore (
http://shop.easternmarine.com/index.cfm?fuseaction=catalog.catalog&categoryID=163). A 205-14 LRC is good for 1760 pounds, a 205-15 LRC is good for 1820, and a 225-15 LRD is good for 2540 pounds.
If you compare just the rated trailer CAPACITY on a single side against the load rating of a single tire, it's pretty obvious that in every case the single tire is over loaded, some much more severely than others. And these numbers are actually light, you really need to add the weight of the trailer into the tire load also:
Not too hard for anyone to figure out that in the majority of cases, running on a single tire on a dual-axle trailer has a good chance of overloading the remaining tire. It's up to you to make the decision on whether your boat (and possibly your life) is worth running on that single overloaded tire.
