The 77 if i'm not mistaken has no points and uses a power pack.
Is there any way to check/adjust the timing?
I put new coil and anew powerpack on it and it seems to run strong and revs high once it gets going but also misses at idle and studders a bit as I increase rpm's, before screaming like a race engine.
I,ve heard that if you change the ignition system you should redo the timing.
Any tips or instruction would be appreciated.
Thanks alot
Chad
Thanks alot
Chad
