Has anyone experienced any issues such as starting the engine and switching all accessories on the helm (e.g. blowers, lights, etc) and the engine shut off?
I think it may be the alternator or voltage regulator. I had just tightened the alternator belt when the issue occured. I had the engine doors open and didn't use the blowers before starting. Once the engine warmed up I switched the blowers on and the voltmeter dropped to zero and the engine quit. Turned on the ignition and tried to restart but no joy. LP fuel pump didn't even energize. All switches on the helm worked with the exception of the blowers.
I shut the batteries off for quit sometime while I cleaned connections, etc and tried starting again and she fired right up. As soon as I turned on the blowers the same thing happened again. I loosed the belt some and started sometime later and switched the blowers on and yet the voltage did drop momentarily it recovered and the engine didn't shut off. Weird... Any suggestions?
