Re: Poppet valve function
It allows water to circulate through the block and then discharges excess water out the exhaust, thus cooling the engine. If you have a water pressure gauge, you would see a little fluctuation in the water pressure when the poppet opens at about 3000 rpm. The poppet valve is nothing more than a spring loaded diaphragm.
