pabloescobedo96
- Feb 7, 2009
- 107
Hello, I have a 1979 35 Johnson outboard model# 35EL79A. I replaced the water pump which requires lower unit R&R and now it pops out of gear occasionally in forward especially at high rpms. The gear lever also moves back when this happens. Did I bend the shift linkage or something. How can I check to make sure everything is adjusted properly. I adjusted the cable a bit more forward bias, but have yet to test to see if this fixed it.
