Re: Help Test OIL/Water Gauges, overheat alarm.
That must be why the water heater only works with shore power. Nice side fix while figuring out this dam buzzer.
Well, removed the electrical tape from the engine plug side and low and behold, there is an adapter. The brown/blue wire (or tan/blue) disappeard at the engine side plug. There is a new wire though, Green could this be it? it sits in as Pin # 10, can someone verify this for me. Should pin 10 be tan/blue?
This same green wire goes directly to the temp switch, ( continuity ).
thanks for everyones help here.
