I opened the value cover and found one of the rockers (3rd from the back of the boat) was not moving. I removed the rocker and found the push rod bent. I am assuming that was where the firecracker knocking sound was coming from. So it appeared the lifter was stuck. An old marine mechanic told me to soak it with WD-40 and PB Penetrating lube and then to hit it with a rubber hammer and a block of wood to dislodge it. Well, I hit it and the spring went down but never came back up. I store the boat on the side of my house and was wondering if this is a project I can fix during the winter/early spring time frame. I do not have the ability to lift the engine out and was hoping this can be fixing in place but I do not see any references to stuck lifters and how to fix them.
Any and all help is greatly appreciated!
Joe
Joe
