Re: 1989 johnson 120 runs 2500rpm at full throttle
Before spending a bunch I would check to see that you are gettijng good spark from all cylinders. By that I mean with a spark testor and getting a bright blue snap that jumps at least a 1/2" gap. Also your description of the way you cleaning the carbs is far less than the steps recommended. There should be a sticky or search on how to do it.
I'm not sue that your 89 has the 2,500 rpm slow feature. My 87s do not.
