hi guys, i must say i joined this forum because of looking through the posts and seeing how helpful and friendly you all are.
i may be on the other side of the atlantic (uk) but hey.
ok my question is this, i have a 71 25hp evinrude, bought her second hand, replaced the plugs, fuel lines etc etc, started her up, ran well a bit smokey, but i think i added too much oil to the mix so not a big deal, i am gonna set up the carb once this job is done.
now she had no water coming out the exhaust, so, i droped bottom end of to replace impeller, saw the water pump body wasnt good either so im going to replace that as well, but what stumps me is.... when the impellor and body are in place, and pushed up onto the shaft, just before bolting up, how do i make the key-way on the shaft make sure its in the impeller groove?
also is there a thermostat on these engines? if so if you could point me in its direction, as i would want to replace that as well to be sure.
thanks for all your help
