Re: How To Increase Your Rpm On Force 85 Hp?
I have a '83 capri 16', I did everything to it I could after putting a new transom in. It had a SS 19p MI wheel prop I sharpened up. Took everything out of the boat I could. It still has the foam in the floor because I didn't want to tear the seat bases out. I put drains in and one side had some water. Anyway I got 43 gps out of it at near 6K rpm, too high. I had the prop thinned and more cup and now it runs 5300-5400 on my new tach, before I had a clamp on test tach. That is still the same 41-43gps depending on weather, and speedo says like 48 or so.
It wants to dip the bow so I straightened the pad some and put trim on the strakes to help keep the bow dry. Still runs flat, was thinking of putting a jack on it but then I need to change the steering cable that barely fits now and not had time to find the stuff I need for that. Also the block has been replaced so likely it does not have that many hours on it. Motor is raised near an inch on the transom, it will cavitate if I trim it way up and holeshot, but it gets up really fast that way. Sometimes it wants to porpoise a little at higher speeds with trim way up and at top speed the last few degrees of trim make no difference. One thing that gives a mph or so is synthetic gear lube. I changed the timing and it didn't help, but you can damage the motor that way I ran premium that time and advanced it, but put it back.
About all I can do is take the floor out and put knees and stringers in, take all the foam out or replace. Put lighter seats in, the jack, and if I can get a good prop on it maybe it I'd see 5mph but I'm not sure about that. I tried a merc 20p laser 2 and it would not pull it at all, it only went 36gps. But that prop needs to have the motor higher to work right so I'm not surprised. Still with a jack I don't think it would pull it without making the boat lighter. The pad is not that bad if you can keep the bow up, but the faster it goes the lower the bow drops. I think it is coming off the center strakes they have a big hook in them, think that is where the porpoise comes from. I sanded those down a little too and it was better, but the bow dropped a little too. I have a jack, water pressure gauge, but no time to do all that yet. I even sanded the pad and LU.
