Re: weight of boat and trailer
Yep, you are over. You need something with at least a 5,000 tow rating, if not 7,000 lbs. Not that the rig weights close to 7,000, but if you gat a vehicle with a higher tow rating, the the towing will be less wear on the vehicle...
2900hull
600trailer
400engine
300fuel(min)
300gear
you are around 4500 by my guess, and that is not knowing if you are an I/O or an outboard or what you fuel capacity is. All of these things are factors...
