keverdmann
- Oct 10, 2009
- 47
I had this in another post but I am moving it because its a different issue.
I have two batteries, they are hooked up to a battery switch. (1, 2, both, off)
If on batt 1 or 2, I can NOT start the engine from the KEY switch (It will turn over just not start). But I CAN start it if I use a screw driver to jump the connection on the solenoid at the engine (as long as I leave the key in the on position).
(I have replaced the key switch and tried leaving the ground off)
Now, Here is the twisted part. If I have the switch on Both. It will start from the key....
These results are consistent and can be produced at an time.
Any clue anyone?
Any clue anyone?
