Tired of always having boats with tachs that dont work right I decided to fix this one.
I knew it was reading high from the sound of it and calculating the MPH speed along with the prop size. What I was not really sure if it was off during high RPMs and right at idle or not. So I ordered a Tiny tach hand held tach unit.
It turns out my true idle in neutral is 850, dash tach reads 1100-1200 It gets worse as the RPMs increase. 4500 is read as 6k by my tach.
I searched the forums for a good while, found no one with a solution to something like this. I would guess my options are to replace the tach or the rectifier? Any ideas?
Its set to 6p I did not find any lose connections. It has system check built in.
It seems alot of people have had this problem and were never able to fix it or never came back to report it.
Thanks for reading all.
