Marty Adam
- Oct 4, 2009
- 8
All three carb were leaking from the front and bottom plugs. I removed all three and installed new gaskets and silicone sealer. All tree quit leaking from those points.
When I removed the carbs. rather than removing the fuel lines, I took the top off of the float bowls that hold the needle valves. I replaced everything and ran the motor. It ran fine, and started easily. Now fuel is dripping from carb throat. I shut off the engine and tilted the motor up. Fuel leaked from two of the three. The floats are not scaled, but are brown. Are they not working properly and have to be replaced or is there an adjusment to be made.
The carbs were rebuilt in a shop. It took almost all summer and I do not need the headache of taking it back if I can fix the problem myself. They charged me very little due to the time and problems that they had.
