Re: Fuel Pressure Problem
Good question...I've never run into a system which has dual regulation. In car the pressure is regulated by a single regulator at the throttle body, or at the fuel rail, but never by the fuel pump.
Ok, looking at it closer, this is a returnless system....meaning there is no fuel return from the fuel rail. Perhaps that's the reason for the dual regulation.
So, you must have blocked 'k' on the drawing, or the return line from the fuel pump regulator, and the pressure went up. This suggests that is was the fuel pump regulator holding the pressure down and that the problem is the fuel pump pressure regulator.
The vaccuum line operates a diaphram which allows the fuel pressure to go higher as the vaccuum goes lower. So, when the engine is under high load (Low vaccuum) the engine will get more fuel. This helps to reduce the amount of time the injectors are open (Duty cycle) to deliver the same amount of fuel. It's pretty standard, and should net 4-6 psi as already stated by boat teck when you remove the vaccuum line (I.E: engine looks to the regulator to be at full load, 0 vaccuum).
Chay
