The previous owner told me he had nothing but problems with this control unit. He said its full of plastic parts, breaks and gets "weird" a lot of times.
I am thinking of changing it to the newest control or trying to fix it up a bit, works as it is but, hoaky. You sometimes have to slam the fast idle lever back down to get it to normal idle speed and the reverse gives barely any thottle (a little above idle speed) no matter how far back its pushed, prolly not good if you have to go into a faster emergency reverse.
Its mounted to a 2001 johnson 60 hp two stroke outboard. Boat is a CC, there are some pretty sharp bends from what I can tell for the cabling.
Even a hint on what its called, model or series wise might help. I could then do research myself maybe and identify if this is control is a dog or not.
Any help at all would be appreciated.
Thank you for reading..
