Re: Should I change LU oil after few hours usage ?
I think most manufacturers reccommend a change every (some number) of hours OR after (some number) of months.
The temperature changes and humidity levels will build up condensation in the leg, regardless of the seals, etc.
I think we all know the real answer is to go ahead and change it.
However, we can all make decisions based on the amount risk we are willing to accept to save a few dollars or hours of our time. Personally, in your case, I think the suggestion to check it for water or milkshake is probably more than adequate. I would change it for sure every two years, but it would have to be perfect at the interim checks. I run mostly 40-50 year old 2 strokes, and they all seem to leak at least a little bit, so for me it isn't even an question. The motor I use the most I pull off the transom of my pontoon boat in the middle of the summer just to change it again. This winter, I will be changing some of the seals on that one (again) to try and make it better.
Good luck with it!
