Re: 2002Yamaha 150 Saltwater Series just quit
how are you testing this?
the red at the pump or brown on the engine side has a constant 12+ anytime the key is on, the ground path is completed by and through the ECU.
the pump is also a 2 stage pump, below about 1200 RPM the pump runs through a resistor mounted above the throttle body and drops pump voltage to about 9 volts.
above about 1200 RPM the ground path is through and by the ECU.
with the key on and the blue pump wire dissconected test for 12V between the red pump lead,still hooked to the harness bullet connector, and ground.
if 12V is present use a jumper between the pump blue lead and the engine block, pump should whine.
if the above checks out and the pump wont whine odds are the pump failed.
