Our 77 Johnson outboard has been having issues. Someone replaced the water pump, and we weren't able to water test it for a while, however when we hooked it up to the hose the engine ran beautifully. We took the boat out later and when it was running in forward and reverse there was an intermittent JERK every couple of seconds, which was more frequent at higher throttle. We replaced the fuel tank (it was the original one) and the fuel lines, the fuel filter looks very clean. We took the boat into a mechanic and he said we needed a new lower unit and that the gears were worn. He put in a rebuilt lower unit. Lots of money later we put it in the water again, the mechanic had disconnected the water pump and the jerking was STILL happening. We took it back, he reconnected the water pump (he did) and said he fixed the jerking.. blah blah. He didn't, it still jerks but now only at high throttle. One of the mechanics said there was something that needed to be adjusted to fix the jerking, something needed to be turned. I don't know what he was talking about, the drive shaft or something to do with the dogs maybe but we're not taking our boat there AGAIN. Does anyone have any suggestions as to what this problem could be. It's shrimping season here in Charleston and we're a boat down!
