Re: 5 hp Low Compression ? Nissan NS5B will not start - has good spark
This is a two stoke, I did look at the valves first just be removing the carb, they appear both be closed, didn't see any crap. I put my thumb over the carb inlet and there was no suction when I pulled the cord.
As far as clean, the top of the piston and the the internal side of the head where shinny clean. Either some has been in there or sprayed an awful lot of starting fluid in there. I always squirt a little spray oil with the starting fluid, better than nothing. I suppose if the rings where bad enough and it ran gas could have gone by and cleaned everything too.
