Re: cleaned carbs and now water pump not working???pls help
I have seen the impeller on some just shear off the rubber from the plastic coller and I have had my own impeller shear off just some of the vanes. But it is easy to check the indicator first, run a small wire or stiff mono in while it is running or pull the hose off. Compressed air can do it also.
