pabloescobedo96
- Feb 7, 2009
- 107
Hello, I have a 1979 35 Johnson outboard model# 35EL79A
Well I had my engine overheat and die on me. The reason it died was the coilpacks on the block melted, and the platic coated the ground for the coilpack so it had no continuity. Well I replaced the coils and it started and ran fine until it overheated again and melted the new coilpacks. well I found the simple problem was a clog in the water line. so I cleared the line put new coils on it again. Now I have good spark at the plugs and plenty of fuel. But it will not run. I compression tested it and it appears to have 30 psi cyl 1 and 35 on cyl 2. I am not sure of the specs but this seems low to me. although they are within the 5 psi window. Anyways I shot oil in the cylinders to check the rings and exact same on compression. It will give me a pop once in a while but wont run. Any help would be greatly appreciated.
