Re: Fuel Pump issue / - POSSIBLY SOLVED
found a loose connection on hose feeding upper carb, appears that was the only fuel leak, engine now idles well on muffs, will take to river later today and see if she'll get up to speed with no further fuel starving issues. SIDE NOTE: engine started much quicker from stone cold this morning in driveway, I'm hoping that's a good sign for this new fuel pump ( I cut-out a flat piece of roof flashing to span the old VROmounting bracket and mounted the new fuel pump flat to that with s/s bolts -real neat fit )
