I decided to pull the floor and found it to be quite unusual. The stringers and foam are fine but the wood floor is rotted, in spots. By the console (by far the worst area) where the throughhull runs to the livewell, where the seats were mounted with very large bolts and where some other item (unknown) was screwed to the floor. There are lots of drilled holes in the floor ?, and one that appears to be from the factory? The previous owner attempted to fix these areas by placing two pieces of 1/2" plywood over the entire floor and glassing it down, but did not fix the leak to the livewell as the new wood was going bad only there. I never noticed the leak as I never went under the console for anything and only used the live well for live bait for my kids.
So could this be what caused the soft spot in the floor? Is it possible for the floor to go bad while the stringers are still good? I poked them with a screwdriver, drilled the foam and both appear ok. The foam is dry. Also the previous owner put some foam in to fill where the wood was gone before putting new wood down. Should I remove the foam or cut it down to the lvel of the factory foam prior to replacing the floor? I am glad I decided to pull it as it seems better then I feared, also the transom is solid, dry and not delaminating. The floor under the rear deck is also very solid (no floor under the front deck). Pics show what I found by the console, between the stringers on the outside of the boat is all foam, nothing between the middle stringers (so water over the bow can run to the back?). Stringers appear to be 1X3 and the original floor seems to 1/4" thick. Thanks for any insights.
Elark7
Elark7
