Blazeracer
- Mar 31, 2008
- 14
I looked through the forum and couldn't find and info on what I need to know within the next day or two... First, a touch of history.
Three week ago I knew nothing of boats other than the new Bayliner I had back in 2000 only needed gas. That boat's long gone. I retired from the Army about two years ago then went right back to Baghdad as a contractor. My time is done there and now I live in Dallas TX where the lakes are abundant. So three weeks ago I buy a boat off of Craigslist advertised as "lake ready". It was for about 45 minutes, then the transmission gears in the lower end cut loose. I found another lower end on Craigslist and pulled the bad one off... WHOOSH.. Out comes half a gallon of water from the u-joint bellows. Turns out is has a one inch tear in it.
I'm fairly mechanically compitent so I order a transom seal kit that has all the required parts. While I'm waiting for the parts to arrive I take a peek under the carpet... Well one thing led to another and now the boat has a new glassed in floor, new paint job, new carpet and a new seal kit on the bellows. While doing the new floor I noticed the front motor mount is sagged down almost a full inch. Not being a boat guy three weeks ago I figured that's how it was supposed to be since it was running before. That new lower unit had to be tapped on the last inch. I think most of you here will know what happens next... yeah.. I'll be replacing the coupling this week. As a result of needing to replace the coupling I'll be replacing the head gasket also.
So, here's what I'm wondering before I pull the motor. What is the front motor mount made of and what should I make a new one out of? When I tap on it, it sounds hollow. Is it just glassed in wood? It seems there should be metal plate or something there, but that's car guy in me thinking that. The guy that knew nothing of boats three weeks ago want's to build it correctly. By the way, I have the tool for ensuring the alignment is correct this time, since I now know that the alignment exists...
