Howdy,
Long time reader, first post.
I recently aquired my G'pa's old '72 Ka-Jun bathtub style bass boat with the Titled engine. Cousin said it was "popping" from somewhere at the top.
So far:
1. replaced all fuel lines
2. new bulb
3. new starter solenoid
4. JUST finished w/ carb kits (had some parts in the kit that went nowhere)
I took it to a secluded ramp a couple days ago to see if it would run. (apartment dweller, no hose). It started (w/ a tiny shot of starter fluid, i know i know bad). It would start, rev to 3k then slowly shut down. The warm-up lever had no control, Incidentally both the throttle and warm up lever would only move the disty in the last inch of travel. Time for a link and sync I'm sure. I have the link to the L&S post and will print it out.
I'm waiting for a fuel pump kit that I THINK I ordered.
My main questions are these:
1. does my problem sound carb/fuel pump/sync related??
2. There is a crecent shaped hole in the leading edge of my LU JUST below the anti/cav plate. SPEEDO????
3. If it is indeed making a "popping" noise from under the flywheel as my cousin stated, could that be the upper end crank seal?
4. There are two holes, on either side of my LU forward of the vent screw, NORMAL??
I'm sorry for the LONG post.
Please help.
Kevin
So far:
2. new bulb
Please help.
Kevin
