Re: Motor on muffs is this normal
There shouldn't be that much water in the mid. Usually that's a sign of the seals on the water delivery tube being bad, or the tube itself is bad.
The muffs will spill any water the pump doesn't take. The pump is positive displacement, so pressure on the input won't significantly increase the flow. Spent cooling water is sprayed into the mid along with exhaust to cool the exhaust, then drains out the prop or drain holes near it. There should never be that much in the mid. There is no oil in the mid to worry about.
hope it helps
John
