2-stroke head case
- Sep 8, 2009
- 10
I have a 1989 19' Bayliner with a 125hp Force L-drive. I was on the bay running strong... I stopped then when I tried to get on plane I couldn't achieve more than 10mph and would not idle (kept stalling). I replaced all the fuel system and cleaned the carbs. Still could not achieve WOT. Only 3000rpm's. I then noticed a spark near the trigger when I tried to get WOT. While testing the cylinders for spark (killing each one individually) #3 seemed to not change idle when shorted. I switch coils... no change. I switch SCR's or CDI boxes and #1 and #3 were dead. Tested Compression and #3 was low with only 35psi. Do you think the trigger is bad also. I know the stator is good it's putting out 210v. Where should I go from here? I was going to pull the head but a mechanic friend said it might be only the reed valves...?
