oldgreenboat
- Sep 9, 2009
- 6
I recently acquired a 14' RyanCraft aluminum jon boat. The rear end of the boat has been damaged by dragging the boat over rocks. The wood transom is rotted and needs to be replaced.
The seam where the bottom of the boat meets the transom leaks. There may be a crack in the tube that makes up the drain hole. The previous owner used Alumi-weld or similar product to make repairs. That coating on the bottom of the boat has some separation. I can put a fingernail between it and the bottom of the boat.
I filled the boat with water and noticed a slight dripping about 1" forward of the drain hole. When I applied slight pressure on a new drain plug from the outside, water seeped from the hole. When I got the boat onto the lake for a test, the boat leaked and I returned only after 10 minutes.
How can I fix these leaks? Will more Alumi-weld work? Should I take the boat to an experienced aluminum repair shop?
I've read about replacing the transom. I'd have to remove the rivets holding the brace to the bottom of the boat, then use bolts.
I have attached a photo of the rear portion of the boat. Thanks for any comments or suggestions.
