I have twin 2001 Mercruiser 5.7 V8 Thunderbolts. I recently heard a strange pinging noise while doing 5 mph going through a canal. I looked at my gauge and saw that I was overheating at 200-210 degrees. I shut that engine down returned with the other one.
I noticed a coffee-beige colored substance on the bottom of the boat and later found out it was oil that mixed with water. The dip stick showed the fluid levels to be within range but there is definitely oil on the bottom of the boat that leaked from somewhere. I also have a small amount on the engine block near the distributor cap...maybe a shotglass full. I can't tell where it is coming from. Gasket?
I changed the plugs to see if there was any water in the chambers and they were dry. I changed the wires and the distributor cap and rotor. Same misfiring sound that gets worse as I rev the engine. After doing a lot of research online I think it might be my risers but I'm not sure why it would be leaking and from where. Any and all help would be greatly appreciated.
Thanks in advance,
Joe
Thanks in advance,
Joe
