old evinrude E70TLCO 85'-87'?
boondox813
am i correct in the year of the engine? im new to boating and bought a fixerupper from my boss had been sitting for 3-4 years got a new battery fuel tank fuel line with bubble . . all the minor stuff to try and get it runnin . . got it goin and it will run for about a minute and cut off but if i keep pushing the electric choke when it starts to bogg down it stays cranked . . i was told that i probably need to extract and tear down/clean the carbs ( this is a 3 cylinder 2-stroke ) was wondering what you all think ? maybe symptoms of other problems? would appreciate any advice
Home Cookin'
Re: old evinrude E70TLCO 85'-87'?
carbs it is. good motor though. I'm on my second
boondox813
appreciate it i got a book in route so i can reference that lol the wires and what not need some tending to as well i just replaced the plugs and wires fires like new, so once i clean the muck outta the carbs should be good to go . . thanks again
Big Bubba
Boondox823,
Yes, you need to clean, clean, clean those three single barrel carbs out really good and use brand new carb rebuild kits. I would also get you a tool made up to remove the orifices/jets or purchase one. That is what I am going to have to do with mine. I have had my carbs off three times within a year but have never removed my jets/orifices, especially the high speed one, and made sure they are 100% clean and you can blow carb cleaner with the small red nozzle attached to the carb cleaner can and spray through it with no restriction. That is what I failed to do but I will buy the special jet/orifice removal tool and do just that. I will use the genuine Johnson/Evinrude carb rebuild kits versus aftermarkets becuase in my experience the fuel pickup tube round gasket seems to get somewhat dissolved so I am thinking I will spend the money and buy the OE carb kits from the Johny/Rude dealer in town and do this right this next time. Also, if you don't know how long the fuel has set in th etank I would dump it and flush it out really good and put fresh 87 octane fue/'oil mixture in it with a can of SeaFoam added to the fuel tank after the carbs have been rebuilt and the fuel tank is cleaned out. Let us know how it turns out I am really anxious to get mine down but I am deployed out of country with the Military. Take care, Bob:)
boondox813
awesome thanks for the info and i will keep ya informed ill probably have more questions for you fine folks
boondox813
any particular fuel treatment/preserver you all recommend? im sure its all about the same price im sure being the only real difference . .
KB_85_V20
your engine is an '85. use the acronym INTRODUCES to figure out what year your engine is. ie. I=1 N=2 T=3 so on and so forth. so yours being CO means C=8 and O=5.
